Problem Mirroring
Problem Mirroring
Hopefully this is simple enough..
Im trying to mirror one set of bodies to another side. If you take a look at the picture, Im trying to mirror the left side across Plane 3. I can mirror it just fine, however that line is there. (The one I circled) How do I merge the 2 parts together?
When I click "Merge Solids" under the Mirror Options, it says "Failed to merge the newly generatedb body with the work piece."
Not sure what to do.. Thanks!
RE: Problem Mirroring
Thank you!! Carry on..
You would have to let the body mirror occur without merging solids and then do a "combine" as the next step. Only combining those two bodies.
Nevertheless, I must agree with CBL, mirror just the side frame and let the horizontal be full length.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
