How To Define A BSP Male Taper Thread on a Drawing
I'm drawing up a custom fitting that requires a 3/4 BSP tapered male thread on one end of it.
I have a copy of BS21 (1995) which defines how a taper thread is defined with gauging diameters and planes etc.
My question is whether this is necessary on the manufacturing drawing. There must have been many thousand drawings of such threads created over the years and I can't quite believe that ever BSP/NPT/whatever taper thread was defined in such detail. Is there a standard convention used to show such a thread on a drawing? eg For an M6 hole, you can just use a note saying M6x1 (6H)
When the part is being made, the length of thread will be constrained by the the base diameter of the material and the cutting die. The die will only cut so far onto the basic diameter of the material before both the major and minor diameters are cutting/touching the outer diameter. I know from experience with taper taps that its very obvious when this condition is reached and you have a fully formed thread. To turn it any further would:
-A: Require big muscles.
-B: Probably break the tap.
Hope someone can advise me on this.
Thanks in advance, AJ
RE: How To Define A BSP Male Taper Thread on a Drawing
Look at this site:-
http://
BSPT threads are designated with an "R" where just BSP threads are designated with a "G"
desertfox
If you are a one-off shop, you make the part and you just know when the thread is correct then why worry about the standard? Unless your cusotmer cares. Or the shop that will make your part cares to provide a part which will work the way you intend.
Ted
• the words "Pipe thread",
• the document number of the standard
• the symbol for the pipe thread type:
o G = external+internal parallel (ISO 228)
o R = external taper (ISO 7)
o Rp = internal parallel (ISO 7)
o Rc = internal taper (ISO 7)
• the thread size
Hi anyoldname
Have look at this catalogue on page 20 its gives the length of thread on the fittings.
I have never specified a length of thread when calling up BSPT threads just the size like R3/8"
desertfox
http://www
What we've always done with odd or non-spec threads, is use a local note with an arrow pointing to the thread location.
In your case,
3/4" BSPT ---------->
or
3/4" NPT ------------>
or
"Whatever" ------------>
Get the picture? Fabrication, Installers, and Maintenance will then reference the proper thr'd. spec. (hopefully).
