Threaded Rod
Threaded Rod
Threaded Rod
I am trying to model a threaded rod with two machined ends. Is there a way to take a solid shaft and use some sort of option to apply a 1/2-20 thread?
RE: Threaded Rod
Cosmetic Threads are your best option.  True helix-based threads would be a resource hog.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
