A simple truss problem
I made a simple truss model but I got an error(a small negative equation solver pivot term............Check for an insuffuciently constrained model). Can anybody please give me a tip to solve?
/PREP7
!Element type
ET,1,LINK8
!real constant
R,1,1.343e-4, ,
!Material properties
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2e11
MPDATA,PRXY,1,,0.3
!Keyponits
K,1,0,0,0,
K,2,1,0,0,
K,3,1,1,0,
K,4,0,1,0,
K,5,0,0,1,
K,6,1,0,1,
K,7,0,1,1,
K,8,1,1,1,
!Lines
LSTR,       5,       6
LSTR,       6,       8
LSTR,       8,       7
LSTR,       7,       5
LSTR,       1,       5
LSTR,       2,       6
LSTR,       3,       8
LSTR,       4,       7
LSTR,       5,       8
LSTR,       7,       6
!Meshing
LESIZE,ALL, , ,1, ,1, , ,1,
FLST,2,10,4,ORDE,2
FITEM,2,1
FITEM,2,-10
LMESH,P51X
FINISH
/SOL
!Fixed supports
FLST,2,4,3,ORDE,2
FITEM,2,1
FITEM,2,-4
/GO
DK,P51X, ,0, ,0,ALL, , , , , ,
!Forces
FLST,2,2,3,ORDE,2
FITEM,2,5
FITEM,2,7
FK,P51X,FX,10
!Solution
/STATUS,SOLU
SOLVE
RE: A simple truss problem
Make sure it is actually a truss (all triangles).  Glancing at it there does not appear to be enough lines for the number of keypoints you have.
Thanks TERIO smile
i found itsmile  you are right, it is not completely truss.
