Looking for thin sensor for detecting silicon wafers
Hello, all. I'm looking for a very thin sensor that I can use for detecting silicon wafers. It is to be used in a robotic end-effector for the semiconductor industry.
I had previously planned on using a thin capacitive sensor which was to be offered by a certain vendor. Since then, I've been told that this sensor might not be offered after all, so I need to start looking for alternatives.
Help?
Help?
RE: Looking for thin sensor for detecting silicon wafers
Where is it to be mounted? Barrell, bracket, tube?
What kind of environment? High temp? Wet?
What are you sensing? Presence, location, position, thickness?
What kind of signal? P-N-P, N-P-N, contact closure, analog?
Who have you already tried?
Love your handle by the way. From Lil' Abner right?
"If it were not for electricity, we'd all be watching TV in the dark!" ...George Goebell.
Hope that helps you.
Chris Elston
Automation & Controls Engineer
http://www.mrplc.com
Download Sample PLC Ladder Logic Code
at MrPLC.com
All other requirements (type of signal generated, etc) are flexible. We can always use adapter circuitry to modify the signal generated, for example.
Subvert the dominant paradigm... Think first, then act!
