Setting 'Hardware Part' property for multiple files
I have a lot of models of screws etc. that I want to define as hardware parts, so that they don't section in draft.
Does anyone know how I can do this without having to do them individually.
I've looked in the programmers guide but the property isn't in the list of file properties.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: Setting 'Hardware Part' property for multiple files
Type: Boolean (true/false)
Avail: .par/.psm
You may also work with the FileProperties client. you will it
within the PropertySet 'ExtendedSummaryInformation' property
'Hardware' or using the ID 'igExtSumInfoHardwarePart'
dy
I can see it now in the list.
bc.
Quadro FX4600.
