pumps outside in freezing conditions
Can anyyone share tips on installation of pumps outside in freezing conditions. We are looking at using vertical turbine pumps to be installed outside, pumping the water from the tank intermittently. I am worried about possible freezing water in the column or around the seal that would prevent pumps from operating.
Thanks all
Thanks all
RE: pumps outside in freezing conditions
1. Use steam tracing to keep your pump warm (or if steam is not available use electric heat tracing).
2. Make the pump run always (using a three valve fitted in your pipeline you can circulate your fluid back to the reservoir and address it to the uses only when necessary): keeping the water flowing will reduce possibility of freezing.
