Displaying dimensions as pararmetric equations
Hi all,
Can some kind chap tell me how to get ST1 to display dimensions as pararmetric equations (like d3=89.5) (i.e. like in Autodesk MD)?
Many thanks,
Anthony
Many thanks,
Anthony
RE: Displaying dimensions as pararmetric equations
RMB on the dimension and you should see Show All Values, Show All Names, and Show All Formulae.
Works in models and in draft.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Couple of probs I'm having:
1) I don't seem to be able to enter the v numbers into a new dimension - ST1 says it doesn't like the format... so I can't just put in V31 for example.
2) Extrusions, for example, seem to be given long names rather than v numbers...?
Cheers!
Anthony
You can also acces all this through the variables tables, then you need only to click on the according dimensions instead of typing the name.
Hope it helps
Patrick
You can display either but not not both.
Maybe an enhancement request is required.
bc.
Quadro FX4600.
