Blower output flow greater than intake?
We are moving air using a 7.5 HP blower. On the suction side we have a filter and an evaporator coil. We are measuring flow using two identical air velocity transducers - one at suction and one at discharge. Both compute SCFM and output a signal to our PLC. We are getting readings of approximately 1400 SCFM at discharge but only about 1000 SCFM at the intake. At one point we put both on the suction line and the readings were the same withing 5% so we are sure it is not instrument error. Both discharge and intake are at about the same temperature and at atmospheric pressure. As far as we can determine the minor differences in pressure and temperature could not account for this. We have been diligently trying to find leaks on the intake side. Other than air leaking into the blower on the suction side, is there any other phenomena that could account for this great discrepancy?
RE: Blower output flow greater than intake?
