collision detection
collision detection
Trying to use "collision detection" while mating parts in an assembly to catch potential errors. Seems that collision detection is a single command and can only be selected when using the move or rotate component function. Any way to combine with the mating process? Any suggestions or is there another way to do the same thing? SW2008 SP4.0 Thanks...
RE: collision detection
-handleman, CSWP (The new, easy test)
