how to check if my lapack,cbas lib support long double type?
I'm using Debian Lenny. I want to know how I can check if my lapack,cbas lib support long double type.
If these libs don't support long double. I need to download the source and re-compile them with long-double option. If I do this, do the compiled new libs overwrite the old libs (which don't support long double)? Will this cause problem for other depdent programs that don't need long double?
Thank you very much!
RE: how to check if my lapack,cbas lib support long double type?
Can you construct a math problem whose results are affected by long double precision?
If you are compiling libraries, you want to back up the old libraries before installing the new ones. The worst case is that you will have to re-install Linux. You have the DVD. There are no licensing issues. You will have wasted one evening. Horrors!
