How to get a linear motor to act tangentially to a cylinder
Hello all,
I am trying to apply a linear motor to the highlighted part in the image below:
As you can see, selecting the outside surface of the cylinder creates a linear motor which acts along the cylinder's axis. However, I need the motor to act in such a way that the cylinder is pushed along the slot shown in the model. The only other parts of the cylinder that I can select are the two faces at the ends and their corresponding edges. How can I go about doing this?
--Amr
--Amr
RE: How to get a linear motor to act tangentially to a cylinder
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
--Amr
