When to replace my hydraulic fluid?
Gents
My hydraulic steering system for the Thruster (marine propulsion) is now 5 years old. The technical department tells me to replace the oil Mobil DTE 25. The oil analysis reports are always good and we use (apart from the designed filters) a CJC 3 micron offline filtering unit and a Kleenoil filtering cart that filters the each (4 systems) for two weeks every 6 weeks.
There are no leaks so the systems do not get fresh oil added.
It is my belief that the existing oil is cleaner than new oil and oil change is not necessary.
I will attach the latest oil report.
Should the additives have been consumed, surely the report would have detected that? However I do believe that our oil analysis are the cheapest possible (not a very thorough analysis) and does not test all that much?
Is the fact that the oil is 5 years old, reason enough to change it?
What tests should I request in order to establish if the oil is 100%, which is no already done? (See report attached)
RE: When to replace my hydraulic fluid?
Is there a specification for Mobil DTE 25? Does it give in-service limits for the fluid? How about for new fluid? You are probably right about the fluid in the equipment being cleaner than new fluid, as 3 micron filtering would get the particle size down to a low value. Though I have no information regarding your system setup, so I don't know how much of a role the offline filtering plays.
You have a report for viscosity, are those within the new or used fluid limits? Is there anything else that's measured or controlled? For Phosphate Ester hydraulic fluid, there are several indicators that the hydraulic fluid should be replaced. Colour, acid level, viscosity, elemental contamination, etc. If these are outside of the limits, they should be replaced.
If the fluid is still within the limits, I see no reason why it should be replaced. Have you tried looking online or asking the manufacturer if there's a life limit on the fluid you've used?
Thanks for your input.
See attached spec for the Mobil DTE 25. As you can see it is within the limits although there are a few characteristics missing such as Particle count, TAN number and Oxidation data.
I cannot find any Life span anywhere but I might contact Mobil to see if they will help.
More opinions are welcome.
At any rate, I would suggest getting both of these sampled and comparing to the standard. Fluid can be filtered to remove particles, and depending on setup, moisture can be eliminated. However, to my knowledge, the only way to get the TAN back in order is by replacing the fluid.
"It is my belief that the existing oil is cleaner than new oil and oil change is not necessary."
There are two reasons to change oil - one is particle contamination, the other is additive depletion. (and if you have really abused oil the viscosity will go away.) As Hydromechdude said you should be checking the TAN. You should also monitor the water content, especially in a marine environment.
At the end of the day it really comes down to maintenance costs vs. potential repair/downtime costs. What are you comfortable with?
ISZ
1) Water content: The result of "NIL" indicates that the lab is performing a "crackle" test, that will only tell you if you have 1000+ ppm of water. For most oils, you should have a Karl Fischer test performed (don't have the ASTM # handy) to get the actual ppm.
2) Particle count: This is going to let you know what amount of contamination you have in your system. The cleaner your system, the better off. "Typcial" ISO 4406 codes for hydraulics are 17/14 or better.
alarm bells: wear debris. (Al) 5ppm, (Cr)9ppm,(Cu)12ppm,(Fe) 26ppm.(Si) 15ppm
Viscosity. 12% of new fluid.
TAN higher than 2 change oil.
new oil TAN 0.2mgKOH grm.The rate of change of TAN number is important more than absolute number.Every oil has a max Tan ask supplier.
herewith a few samples of wear metals, iron,chrome,nickel,aluminium,copper,tin,lead, a PQ Index is good to have. Contaminants silicon,sodium, water, there are also additves.
Looks like something was done between september and october that caused a change in a lot of the numbers - like fluid was added maybe?
Where are the numbers of the oil when new? Given this data we can only trend the system - but I don't see the OEM numbers to compare to the oil as it sits "on the shelf".
Chris
You may want to check out the Hydraulic Supermarket. It has a wealth of info on hydraulic systems and will help you with your question. There are several acticles written there that will give you the information about what to check for in your hydraulic fluid.
ISZ
