IR temp Sensor
IR temp Sensor
IR temp Sensor
After doing an exhaustive search on Google, I though I'd ask you guys.
I'm looking for a IR temp sensor that can easily connect to a pc, by either rs-232 or usb. If you have any suggestions, I'd appreciate it v. much!
Thanks!.
RE: IR temp Sensor
I did some switchgear for a test cell a couple of years ago, used an analog output IR sensor from Omega and an analog to serial convertor from B&B Electronics, worked well and is still working as foar as I know.
Hope that helps.
