Simulation: Combining load cases for imported results
I have a simulation file into which I've imported results for four subcases.  Is there any way to create a linear combination of these subcases without having to solve the model in NX?
From what I see in the help menus, the only way to combine load cases is to right-click on the "results" node in the simulation navigator - which doesn't appear unless you've solved the model in NX...
