Transformer Rating
Transformer Rating
Given a Transformer without nameplate, how do I find the find the Rating of the transformer at site where there is 415V?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Transformer Rating
Is it in service or sitting idle?
Where did you find it?.
What do you know about its history?
Photos?
Size and type of transformer? dry/oil filled?
Physical condition?
Voltage ratio? Meggar readings?
Type and size of windings conductors?
If you have most of the above info, there may be a remote chance of estimating something.
Rafiq Bulsara
http://www.srengineersct.com
"If you have most of the above info, there may be a remote chance of estimating something."
Muthu
www.edison.co.in
When the current starts to increase disproportionately to the voltage increase, you have reached magnetic saturation. The next lower reasonable standard voltage is probably the rated voltage.
Bill
"Why not the best?"
Jimmy Carter
Grin!!
Nothing is impossible, just takes longer and costs more money!
Rafiq Bulsara
But the volage I have at site is 415V. If I apply 415V the short circuit current obtain is small. How can I obtain the percent impedance with 415V?
You can't use that transformer at 415 V so why do you need %Z at 415V?. %Z is only useful at rated voltage ranges.
What are you trying to test or achieve?
Rafiq Bulsara
Bill
"Why not the best?"
Jimmy Carter
If you require the transformer to be in working condition than others here will have more useful suggestions.
Amps = kVA/kV/sqrt(3)
You could assume a percent impedance and do a short circuit test per your previous post and Bill's post on ratios. Then you can calculate the kVA that will give you the assumed impedance.
The problem is, for a 132-33 kV transformer, impedances range from 8.5% to 13% (this is from an old Westinghouse T&D Manual and may not be current). This method can only get you into a range of kVA ratings.
