NX6 - Unwanted post output.
I am re-writting our PP's but the output from the post always includes the below infromation.
Does anyone know how to prevent the post outputting this infomation?
Information listing created by :  RCarresi
Date                           :  08/01/2010 14:42:00
Current work part              :  7119825_78_H630/A
Node name                      :  cragb354
Many thanks
Richard
RE: NX6 - Unwanted post output.
You must have a header custom command in your start of program that is creating that information.
Are you sure that information is actually in the file?
It looks like the header from the information window in NX that automatically "pops" up after posting.
Try to locate the actual, processed file and see if that info is there. I bet it isn't!
J
Hi Jaydenn,
I am trying to find where NX is saving the nc output but the 'Output File' dialog is greyed out.
Do you know how to make this selectable so I can browse for a location to place the nc file?
Cheers
Are you in a managed or native environment?
In a managed environment, the output file will go in to Teamcenter.
Mark Rief
Product Manager
Siemens PLM
It's managed but saves it into my temp file on the c: drive.
I have found the file but now want to specify where to save it.
Is there a variable to do this?
regards
Richard
