Mass of Frame components in parts list
I can get the cut length of frame components, but I want the weight of each bit also.
Does anyone know if this is possible?
I just get zero.
I just get zero.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: Mass of Frame components in parts list
I suppose thses are for ST3 :)
as long as the generated frame is not saved out as a separate
assembly the parts are only virtual ones and have no mass. Only
the containing assembly will total the mass.
To get the mass for each of the components you can do it this
way only:
- RMB on Frame Components
--> choose Save As
Now all parts will be generated(!) and thus should have a mass.
Drawback: the created assembly is not associative to the
creating assembly.
dy
As the customer insists on having a mixture of alpha and numeric item refs, the parts lists for assemblies have to be dropped/manually entered anyway so I will just put them in manually.
bc.
Quadro FX4600.
