AHU approach
AHU approach
almost all of the approach of my AHUs in my building are very high eventhough it has already under gone its cleaning by pressure washer. the range of approach is 5F to 10F.
as what i know, the approach of the AHU should be normally ranging from 0 to 3F.
what could be the cause of this high AHU approach??
RE: AHU approach
RE: AHU approach
RE: AHU approach
RE: AHU approach
RE: AHU approach
it is chilled water, fin spacing is 2.12mm... the coil face velocity is 2m/s for air... right???
RE: AHU approach
