Execute Geostar from Matlab
Hello every body,
I'm new on the forum, so i hope i whrite in the good forum. The question is in the subject : do you know the command line or script to execute geostar (the "brain" of Solidworks FEA Simulation software) from the soft Matlab ? I have already the script for Ansys, but I don't find the same for geostar.
Thank you for your answers.
Vince
Vince
RE: Execute Geostar from Matlab
It seems to me that once upon a time I did this, but since geostar is a user interface I am not sure what this will buy you. It used to be you could contact SRAC directly but with SW interposing their people now the chances of finding someone who knows how to do this is slim.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
TOP
CSWP, BSSE
You can run GEOSTAR from a MS-DOS window issuing the following command:
GEOSTAR "problem_name" "model.geo"
if "problem_name" do not exist, then GEOSTAR will create the database. And also will read the content of file "model.geo" and will execute line by line and then to create the data base.
In order to run GEOSTAR from an MS-DOS window or script command from MATLAB you must make sure to add the COSMOS path to the system PATH variable.
Best regards,
Blas.
And you can programatically write any commands you want in the .geo file. Either a full blown analysis file or just some tweaks to parameters.
TOP
CSWP, BSSE
