Derating Cable for High Altitude / Elevation
Where can I find some instructions on how and when to derate cable for high altitude applications? It does not seem to be mentioned in the NEC.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Derating Cable for High Altitude / ElevationDerating Cable for High Altitude / Elevation(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Derating Cable for High Altitude / Elevation
Transformers and switchgear get derated at high altitudes, but I have not seen it done for cables. It makes sense, the less dense air has less cooling capability, but how much?
1000m = 100%
3000m = 96%
6100m = 90%
This is the current derating for fuses, enclosed air disconnects, metal enclosed and metal clad switchgear. Basically, it accounts for the reduces cooling effect of the less dense air.
As already pointed out, the insulation strength does not depend on air pressure so it would not de-rate. But, any place relying on through air clearances should be derated as follows;
1000m = 100%
3000m = 80%
6100m = 56%
So, say you require 3/8" clearance minimum for 480V. At 6100m this would be very close to 3/4" required.
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
