Void Forms for Expansive Clay
I'm designing a building that is on a site with expansive clay soil. Deep foundations (drilled shafts) and grade beams will support a structural slab at the ground level. I've looked at several different products for this application; the more typical "cardboard" type and the "rainy day" metal type for grade beams and slabs.
What I'm looking for is whether or not void forms completely degrade and absorb all the soil swelling pressure or if they still transmit some of the upward swelling pressure. I can't find this information on any of the products' websites.
The geotechnical report for this site says that swelling pressures could be as high as 2000 psf if no void form is used. It recommends void forms to help "reduce uplift forces" but it doesn't say what that reduced force will be. I understand it probably differs based on each product, but I can't find that info.
RE: Void Forms for Expansive Clay
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
I'm looking for data where the compressive strength of the form has been tested after casting of the concrete and water has soaked the form.
You need to read again. The link rowingengineer gave states that the void after flooding is 60% of the original height of the void former. It doesn't collapse 60% due to the wet mass of the concrete.
Dik
Edmonton clay is expansive and I usually specify a 4" thickness of GeoSpan under grade beams. This seems to work reasonably well in most cases, but there are times when a greater thickness is warranted.
h
BA
Curios and want to learn more on this.
So, the soil has a potential to exert 2000 psf pressure (after DL) on the structure, then there are two scenios:
1. use 4" form to obsorb 50% of pressure, and design the grade beam/slab to resist the rest (7.3 kpa approx = 1000 psf).
2. use 8" form to relief entire pressure.
I don't know if I have worded my question correctly or not, you can see I am lost in somewhere.
Apreciate your comments and further explanation.
Basically the question is "how much compression can wet cardboard trasmit?"
In my head, I'm thinking of it as the linear-elastic / perfectly plastic stress strain curve we assume for steel. The wet void form will carrying the swelling pressure, transmitting an increasing amount of compression to the structure, until it finally crushes and continues to crush while applying the same load.
BAretired says his product is 7.3 psi. That's the number I was looking for. The geotech eng said the metal product crushed at 500 psi (which shocked the crap out of me) but I think he may have meant 50 psi. I saw an online brochure of the product and it's nothing more than corrugated chicken wire. There's no way that stuffed with-held 500 psi.
Quote: Basically the question is "how much compression can wet cardboard trasmit?"
That's exactly the question I have in mind.
No kidding, 1000 psf uplift? I think you need to follow up on BAretired's lead to select a form with proper thickness to further reduce the pressure to a more manageable level. Keep me posted on your findings. Thanks.
And if it is that strong, why is the product designed to be so strong when all that it is need to carry is the self weight of the concrete; 100 psf for an 8" slab or 400 psf for a grade beam?
Am I missing something here?
and, as the question you have raised, what is the form of complete collaspe, by what pressure?
Maybe I missed something, but that's why I am sticking to it :)
Last month, some were installed under some new grade beams at my house (on swelling clay) with the trade name AVOID - clever, eh? I believe I could have stomped them flat without much trouble. They were just cardboard boxes with internal stiffeners, designed not to crush under the weight of the concrete, about 4 psi in this case. They could not have been very stiff in compression.
So the question should be "what is the anticipated volumn change of the soil", a pure geotechnical question, am I correct?
For checking pile reactions worst case downward, there isn't an ASD load case that has D and L but not H. For designing the grade beam's worst case downward, there is a case with D and L but not H, but that case is only 1.0L and not 1.6L.
If I blindly went by the combos listed I would be assuming that the uplift swelling pressure occured 100% of the time (which isn't true) and would never get a worst downward case.
Does anybody agree with this?
But IBC 2006 pulled all load combos and reverted back to ASCE 7.
That's part of it - how fast does the pressure reduce with swelling allowed, versus how fast does the void form pick up the load with compression? Seems it would take a significant amount of upward movement of the underside of the beams to get the piers (normally in compression) into tension. (Don't ask me to quantify "significant.")
I think a leason is learned today. Thank you very much.
The attached graph shows Compressive Stress vs Percent Deformation.
The magnitude of heave varies from place to place. It may be caused by swelling clay soil, frost heave or both. If you experience a 2" heave and use 4" GeoSpan, the Percent Deformation will be 50% and the pressure would be about 50 kPa. If you get only 1", the deformation is 25% and the pressure would be about 40 kPa according to the graph.
If you are expecting more than 2" heave, then you should use a thicker voidform.
The answer to this is "You bet!" A 12" x 24" grade beam weighs 300 plf so the net uplift is only 700 plf. You likely wouldn't have less than 3 - 15M top and bottom, so the uplift is carried by the grade beam spanning between piles.
BA
But it appears you don't have to. It appears that properly designed cardboard products will on average degrade down to 30% of the initial strength.
Read this
http://surevoid.com/product/testing.php
it is testing done by a manufacturer to determine strength reduction. they show that strength reduction can reach 80-90% based on the amount of moisture absorbed.
The numbers we really want are wet compressive tests.
BA
I spent 30 min on the phone with one of their owners. He knew this product inside and out. Basically the strength reduction is a function of the moisture absorbed as a percent of the void weight.
At 20% moisture absorbtions, their product lose 60-70% on average. Some products lost up to 80% strength.
But it really all depends on the moisture levels of the site and the soil of your project.
Based on their testing, I feel comfortable designing my grade beams for an applied swelling pressure of 500 psf. This is a conservative estimate that a 1000 psf form will degrade 50% of it's strength. That probably corelates to about 10% moisture gain.
(1) Length of time between initial void form placement, cover and section casting.
(2) Effects of Soil Poision Treatment moisture.
(3) Effects of Ambient Air/Soil Moisture.
(4) Capillary Moisture Rise, especially so at grade beam sections.
(5) Deflection strengths of the Void form Cover Sheet.
(6) The most important... FOOT TRAFFIC Degradation!!
All of these six things I list have a direct influence and correlation as to how much void section height remains. After subtracting these considerable losses, what actual void heights can be expected at the Time of casting?
Plastifab also manufactures Geogrid which is a lower strength void form that can be used under slabs...
Dik
Here is a link to Geovoid by Plasti-Fab:
h
Another slab voidform by Beaver Plastics is Dynavoid:
http://
hokie,
The upward pressure is not a problem if the slab is designed to resist it.
I had a nasty experience with cardboard voidforms a few years ago on a 10" thick structural slab for a liquor store. Two types of cardboard voidform were available, waxed and unwaxed. The contractor chose unwaxed.
Before he could pour the slab, the voidform was saturated with rain. It collapsed under the weight of the wet concrete. What a mess! The entire slab had to be removed.
I suppose the waxed type would have worked adequately, but since then, I have avoided cardboard voidform like the plague.
BA
My wife and I went to NYC this past Sept and got to see the Federer - Del Potro mens singles final at the US Open. Besides college football, it was probably one of the best sporting events I've ever been to.
Dik
http://
John Southard, M.S., P.E.
http://www.pdhlibrary.com
