Opening an Inventor.dwg with AutoCAD
I know you can open an inventor.dwg in AutoCAD. However, when ever I open, it comes in "sheet" not model space, and my dimensions are in "inches" not millimeters.
I'm not so concerned about it opening in "Sheet space" but I do require the units to open in millimeters.
If anyone has a suggestion, it would be greatly appreciated
Matthew
Matthew
RE: Opening an Inventor.dwg with AutoCAD
You could get someone to export the Inventor file as a STEP file, which you can import into Microstation and then save out as a dwg. It's a round-about process, but it will come in with true dimensions.
