Extrude Direction 2 Settings
Does anyone know how to alter the settings in the extrude function to enable the direction of extrude to go both ways in direction 2? My software only shows direction of both ways in direction 1. I am using 2007 version of Solid Works software. Thanks in advance
RE: Extrude Direction 2 Settings
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Why would you need to extrude "both ways" in direction 2?
Direction 2 is only used in combination with Direction 1 and is therefor "the other way".
Craig Pretty
Tru-Design Plastics
Craig Pretty
Tru-Design Plastics
