HSS beam to HSS beam moment connection
Does anyone know of a reference for designing a moment connection of two HSS beams using end plates?
Basically a flange connection as you'd see in pipe spools but using square HSS.
RE: HSS beam to HSS beam moment connection
Yes, this is indeed my intent.
Is that a splice? Beam to girder? Beam to column?
The black AISC HSS Connections Manual has this connection, for both rectangular and round tubes. The examples are for axial load, but a small transformation will convert your moment into an equivalent axial.
maybe without an end plate would work as well - similar to AISC 13th ed. Fig. 12-7 p.12-11
