SOLIDWORKS 2009 SP4.1 RADIAL LEADER SNAP
Is anyone having issues trying to change the Radial/Diameter leader snap under document properties. It allows me to change the default of 15 degrees, but when I go back to document properties it is still is at 15 degrees. My change will not stay.
THANKS
THANKS
RE: SOLIDWORKS 2009 SP4.1 RADIAL LEADER SNAP
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 4.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Tools/Options/Document Properties/Dimensions
Can not get "Radial/Diameter leader snap angle" to change and stay. I think this started after we went to SP4.1
THANKS
Mechanical Designer
I like my set to 1 degree, it makes it a little eaasier to position dimensions on a busy drawing.
Best,
Colin
Mechanical Designer
You may want to try using the Save settings option under Drafting Standards in Doc Props to export a ANSI_1degsnap.sldstd file. Then see if importing the file changes the angle setting to the one you specified before exporting.
Michael
Thanks for the idea.
Bryan
