Dterming the flow direction of Pitched Blade Turbine 45degree
How do we determine if the flow generated by a PBT is up-ward pumping or down-ward pumping?
RE: Dterming the flow direction of Pitched Blade Turbine 45degree
look at the direction of rotation and visualize a threaded bolt.
