Does a 60 Amp toggle switch exist?
I'm building an electric-assist bicycle with a current power suppy of 24VDC @ 48A and an auxillery supply of 24VDC @ 17A. The power controller I have can accomadate up to 60A at the same voltage so there's room for improvement. To maintain this possiblity however, I need an On-Off-On toggle switch cappable of handling a constant 60Amps. I also require a keyed, On-Off switch that can handle the same current for safety/security reasons. I've searched many places on and off the internet and I can't seem to locate either type of switch.
Does anyone have a lead or link to a store that supplies/produces such toggle switches if such things exist?
-DERCANDYMANN
"I can do all things through Christ who strengthens me." Philippians 4:13
RE: Does a 60 Amp toggle switch exist?
The traditional solution is DC Contactors (think Ford starter relays) controlled by regular switches.
Mike Halloran
Pembroke Pines, FL, USA
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
-DERCANDYMANN
Look at these:
http://www.colehersee.com/catalog_top/index.htm
Click on: Battery-Related Products
Click on: Battery Disconnect Switches
Click on: Next
For key operated switches find "Hencol lock & two keys" in the actuator field.
Note: these keys are widely available. Almost anyone who has operated cats or Cat loaders will have one on his key ring.
For an electronic relay, go to:
http://relays.tycoelectronics.com/auto.asp
and look for:
V23130-C High Current Devices, Battery Disconnect Switch BDS-A
Bill
"Why not the best?"
Jimmy Carter
