Temperature Preload from Transient Thermal Solution
Hello
I am doing a project in Advanced Simulation module which involves moving heat-source. Thermal solution has got 100 time steps sampled to 50 results. I need to do a structural analysis to show stress and displacement using temperature preload from thermal solution. Now the problem is that I want to specify which one of those 50 results is used to map temperatures in structural analysis. Is there any way other than doing thermal analysis 50 times to have 50 increments?
Best Regards, Koen
Best Regards, Koen
