capture velocity
capture velocity
Does anyone know much about capture velocity?
Has anyone out there done any experimental work to determine what the capture velocities might be for various contaminants and various environmental conditions?
I have read what the Industrial Ventilation Manual says about this. I just want to know more.
Thanks for your help.
RE: capture velocity
I would recommend looking at ANSI Z49.1 for more info. The COE had me deliver a paper on this in 1995-I don't have a copy anymore, but they might hve it on their web site.
Capture velocity means a lot more when you have capture distance included. OSHA and ACHIH do not cover that. I received a field interpretation from OSHA approving usage of 9" capture distance; after that, air arc gouging was the only problem. Had to do repetitive mock-ups with a millwright until the enclosed LEV would meet standards.
Thanks for your helpful response.
I am curious. Were you ever able to control the contaminants from air arc gouging? If so how did you do it? Was the hood easy to reposition as the operator moved around? What size were the parts being worked on? I suppose they were fairly small if it was a training facility.
Thanks again.
The design was trial-and-error, prototyping variations from the ACGIH until we could demonstrate 100% passing on personals at the action level. Copper was the kicker on this one, and we used it as the baseline for passing all other analytes. Once the action level was met, no other analytes came near to STEL or action level.
Air arc gouging is a very messy business, and after training, the idea is the field work will be done outside. Up until that time, it had never been done in doors while meeting OSHA/ACGIH requirements. I beleive that the DOL, AIHA, and CERL also had papers presented and available off the web. I though about using computer based modeling at first, as alot of research was available out of Japan at the time; however, none of the Japanese (Kobayashi, I beleive) computer models passed in real life.
It wasn't really as much engineering as trail-and-error on an accelerated basis.
I may have an application where I need to control air arc gouging indoors. The problem is that the part is quite large so the worker is constantly moving around it. Local exhaust ventilation is probably not possible so general ventilation may be the way to go.
Thanks again for you help. Your work on that project sounds interesting.
Wherever you're aiming the slag, that's where you will get the greatest exposure potential; the air wand pretty much overcame any normal dispersion, which was why directional control was possible. As it was a training facility, the enclosure, back exhaust and push exhaust were aligned in slag direction. Multiple position, and especially vertical, were not considered. Trying to move air away from gouging direction did not work well on any prototype. Containment (enclosed by steel) were used inside of general exhaust.
Handling the slag was also an issue. You are talking about shooting plasma in any direction. It's a very serious safety problem, and the slag ate up most surfaces (or rather deposited on them heavily). Best I could think of is refractory, which might not be doable at multiple positions.
It may have been 15 years ago, but at that time it was held to be undoable even for training purposes. The first two EOR's paid liability, so you are not going into a historically easy area. I hope you have a good CIH. Good luck going to production.
mauricestoker: I think I would opt for a general ventilation system. I don't think a local exhaust hood could work for this gouging application. I would bring in fresh air at about 4 feet off the floor facing the tradespeople and exhaust up high, diluting the contaminants to acceptable levels in the breathing zone.
I also did some grinding dust collection equipment for use in house and found with a large shop vac we were able to get 1000fpm at 8" from the inlet (worked for nuisance dusts generated by grinding equipment- heavy particulate still collected on the floor...)
fyi
Mike
