Tightlining around a tank
As part of our gathering system we have centrifugal pumps that feed oil down a 4 mile line to a storage Tank.  From the tank we have a PD pumps that move the oil farther down the system.
Due to the high cost of tank maintenance/inspection we are discussing tightlining around the tank.
I am unsure whether we can accomplish this with the existing PD pumps.  I don't see how we can  feed the PD pumps with the centrifugals and get it to work correctly.
The PD pumps are not on VFD.
Can someone help me out
RE: Tightlining around a tank
At what rate are the pumps running, and what is their range? (GPM)
"I came, I saw, I made it better."
-Ode to Industrial Engineers
Will ChevronTexaco Corp.
If the PD at constant speed is in a good range of operation for the centrifugals and discharge pressure is within maximum centrifugal suction pressure, why not?
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
