Trimming Entities
Trimming Entities
Trimming Entities
Hello all,
I've been struggling with a simple little part that shouldn't be this difficult. I'm hoping this will be just a simple command that I am missing but none the less.
In the attached part I am trying to delete the piece of extruded circle on what would be the inside of the "L"
Thanks in advance for any help you guys could provide.
RE: Trimming Entities
I have attached the 2010 part. Incase you cant read it, please see below discription.
- L Extrude can be just a surface instead of solid
- If it has to be a solid, please uncheck the Merge result in the extrude command
- Offset a face of the L with a zero dist.
- USe insert -> split & choose the body
- Finally use delete bodies & delete the unwanted bodies
~ BT
1. Select Sketch1 in the feature tree
2. Insert->Cut->Revolve
3. Hit the checkmark.
4. Select the body you want to keep.
-handleman, CSWP (The new, easy test)
Handleman's method works if you don't need to keep the "L" flange.  If you do, use Sketch1 and it's Plane to create a new Sketch to cut-revolve the section of tube, leaving the rest.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Umm, when I do it, the L flange stays.
Guess it depends which way SW picks for the thin feature.  You might have to change the thin feature direction.
There's also the option to delete the three faces that form the portion inside the L (using the Delete and Patch option).  Not necessarily the best option for simple geometry like this but this can be extremely useful on irregular geometry.
Thanks guys,
I need to keep the L flange and delete everything on the interior of it.
