Re-rate of pre-1968 vessels
Does anyone know the reason why vessels that were built to the 1968 or previous editions of the pressure vessel code cannot be re-rated using the current code?
Re-rate of pre-1968 vesselsRe-rate of pre-1968 vessels(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Re-rate of pre-1968 vessels
what is the material specification for your static equipment built to the 1968?
L S THILL
What environment will the material see?
We have vessel fabrication drawings but no certified documentation for the vessel rating. There is not a U-1 and the nameplate is missing.
I am to perform the calculations to verify the rating of the vessel. I was under the impression that you had to use the code of construction if the vessel was built prior to the 1968 edition of the code. I now see that you just have to use the allowable stresses from that code.
The vessel is in pentane service.
Design, construction and welding to be in accordance to the 1952 edition of the ASME code for unfired pressure vessels.
Can you elaborate what exactly happened in 1968 Edition ASME BPV Code to make NBIC to choose this edition as the cutoff year? I cannot find info about significant changes in 1968 Edition other than Div.2 was first published in that year. The new impact test rule was not implemented until 1987.
Our only deviation from the original design is that for most of the equipment we require PWHT for all thicknesses due to service.
The only piece of equipment that presented any problem as to reevaluation of the original design was a Horten Sphere used to store anhydrous NH3 for several years.
Why? Because from my recollection, the Bessemer steel-making practice (which produced plate steels with higher phosphorus contents and lower notch toughness) was phased out around the late 1960's and the basic oxygen furnace (blowing with oxygen instead of air) and electric arc furnace melting became the choice of most fabricators.
2. In the old code, there is a 0.95 joint efficiency limit with full RT. When you rerate old vessels with latest software (with old allowable stresses), do you use E=0.95?
Yes you should. In accordance with the requirements of the NBIC, you cannot take advantage of a higher joint efficiency for re-rating.
