Transucer: input -10 to 10V, Output: 0-1ma
Was wondering whether it would be possible to get some help concerning transducers. I'm working on a project that needs a transducer which will accept an input signal -10 to 10 V and outputs 0 to 1 mA signal.
Seeing that the industry standard now a days is 4 to 20mA I'm having a hard time finding this type of transducer and would like to know if anyone can lead me in the right direction.
I thank you very much in advance for your response.
RE: Transucer: input -10 to 10V, Output: 0-1ma
Can you define the project for us?  Are you making 1 or 1 million?  It makes a difference as to what type we suggest...
Dan - Owner
http://www.Hi-TecDesigns.com
In commercial packages they're generally called signal conditioners.
API 4300G
http://www.api-usa.com/pdf/api/api_4300g.pdf
According to the spec sheet:
- input range -10 to +10Vdc
- output range 0-1mA dc
