600 volt insulation for neutral on medium voltage system
Why does the code allow 600 volt insulation on the neutral on circuits of 1kv and over?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: 600 volt insulation for neutral on medium voltage system
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
Are you sure that requirement applies to solidly-grounded systems?
I checked and that requirement is for a system with a neutral resistance. Solidly grounded is 600 volt.
