2mm flat cable
2mm flat cable
I have a piece of equipment I'm trying to repair and it uses 2mm flat cable (i.e. ribbon cable) with four conductors. I see Molex used to make some (24463, 24473) but it is obsolete. Does anybody know who is current manufacturing ribbon with 2mm pitch? I haven't measured it but I'll guess it is 26 AWG.
John D
John D
RE: 2mm flat cable
Keith Cress
RE: 2mm flat cable
Any way you can change the connectors used so a standard .1" cable can be used? Have you tried the regional Molex rep to see if he has a few feet lying around?
Dan - Owner
http://www.Hi-TecDesigns.com
RE: 2mm flat cable
Keith Cress
RE: 2mm flat cable
Dan - Owner
RE: 2mm flat cable
I know somebody makes this stuff, because I see it used all over my son's Lego toys. Oh well, I might just have to replace it with individual wires and lose the 'pretty' factor. Or I could buy some new Lego to scavenge...
John D
RE: 2mm flat cable
Dan - Owner
RE: 2mm flat cable
John D
RE: 2mm flat cable
ht
TTFN
RE: 2mm flat cable
