Importing Adobe Illustrator Drawing to trace over
If you're working on SW 2006 and latest versions, and if you want to import from Illustrator, from there you have to save as CS version, because if you save it as CS2,CS3 and CS4 you'll have troubles and you won't see nothing. But you will see only vector line without colors and textures.
RE: Importing Adobe Illustrator Drawing to trace over
tahuilan ... If your post was intended as an informative post rather than a question, please select the Edit Post link at bottom centre of the post, change the radio button option to Helpful Tip, and then Submit Post again.
Then Dan won't have to stay awake all night waiting for the question. lol
No, I'm responding to a previous question. About importing from Illustrator to SoldWorks 2006.
If you are referring to thread559-103208: importing Adobe Illustrator Drawing to trace over, that thread is over 4 years old. If a thread has been inactive for 6 months it is closed for further comments.
However, when referencing closed threads, please specify the thread number. Just typing (or copy and pasting) [b]thread559-103208[/b] will show the full title when posted.
Ooops ... please ignore the codes aurrounding the thread number. It should have read;
Just typing (or copy and pasting) thread559-103208 will show the full title when posted.
