Coating for Carbon Steel?
Dear All,
I am looking for a material that will bond to carbon steal to create a coating what will be very resistant to abrasion and will insulate the metal electrically. Does anyone have any suggestions?
John McGrath
John McGrath
RE: Coating for Carbon Steel?
John
I just need some help in finding the right one.
Thanks anyway,
John
Don't be too quick to discount Rubber.
Some silicones are good to 315 deg C (599 F) and 245,000 ohm-cm.
About a month ago there was a thread on ceramic sources.
Coors Porelain in Golden, Co and at least one other. Ceramic might not be flexible enough for 15" rad. It depends on the cross section of the steel (actually Moment of Inertia) and the Modulus of Elasticity of the ceramic. If it is a very small cross-section, it could work. You might need to thermally spray the coating which I believe is termed plasma spraying. Or you could coat with Aluminum Oxide Al2O3 using the Mo-Mn process which is a fairly involved technique but achieves very strong bond between the steel and ceramic. However, at 400F the differential in thermal exansion between Carbon Steel and Al2O3 might be enough to crack the coating. Are you stuck with Carbon Steel? There are other metal alloys that have thermal expansion coefficient that match closely with ceramics. One is named Kovar that matches with Al2O3.
Leonard
Jesus is the WAY
1. There are many different ceramics.
2. Many can be made readily brazeable
3. They can pretty well be cast in any shape you wish
4. Is this a fixed bend or is it going to be flexing?
5. You can compensate for the differences in rates of thermal expansion with proper joint design and braze alloy. We did a lot of work on this with Weyerhaeuser years ago. See www.carbideprocessors.com - brazing book
6.
How’s TiCN?
Electrical Properties Property Value Units
Electrical Resistivity 17-22 x10^-6 Ohm's x cm
Magnetic Suceptibility +10 x10^-6 emu/mol
Superconductive Temperature 10 K
Tom
The metal that is going to be coated is a 0.108” strand of carbon steel wire that will be lowered in on oil well for 18,000 ft and then pulled back out again several times. The bottom hole temperature can get up to 400F as well as having various chemical such as H2S and CO2 down there. I’m pretty sure that rubber will not be able to take the combination of wear, temp and chemical attack and still give an acceptable life span.
For the wear at temperature and chemical inertness my money is on a ceramic. Can you recommend any sources where I can get better aquainted with current ceramic technology and capabilities?
Thanks for your help,
John
Leonard
Jesus is the WAY
Generally thin layers of TiN or TiCN (less than 3 or 5 microns) should be okay. These coatings are PVD or CVD coatings and will cost $$$.
The wear seems to be between the wireline and the pipe. The general hardness of the pipe is around 25HRC and if your wire line is tribologically compatiple with (slightly harder than?) the pipe, it should not wear much. Where does the abrasion mechanism comes from? maybe from the ingrained sand or drilling medium? Make sure the type of wear (adhesive, abrasive or corrosive) you are attacking before selecting a material and/or coating.
I would be happy to discuss with you the details. Please contact me at <kumar@asm-usa.com> or visit our web site <www.asm-usa.com>
Sivakumar
Pardal
Teflon will not take the extream abrasion that I need for this application.
John
Ok, teflon will support the 400 °F , so add a shield as on shielded wires, it could be stainless stell web.
Sure you can get a vendor for 12000 ft wire.
Pardal
Pardal
The shielded wire that you mention is available from several different suppliers and this is what has been used for 30/40 years in the oil field applications that I am looking at. There are several inherent problems with this design and the solution that I am looking for (i.e. a smooth coated wire) will solve them all.
I just hope that the technology is out there to do it.
John
why don't you try CVD diamond thin films too guarantee the abrasive actions in the wire?
