Deleting an extra Revision Symbol
Can someone explain how to delete an extra revision symbol in a SW drawing? Occasionally I'll click one too many times and place an extra revision symbol on a drawing. When I delete that symbol, all revision symbols at that particular revision level are deleted also. I'm sure there is a simple solution, but this is quite frustrating. I'm using SW 2009.
RE: Deleting an extra Revision Symbol
First one is "Do you wish to delete corresponding revision table row?"
Second one is "Do you wish to delete corresponding revision symbols?"
If you have selected the "Do not ask again" option (see attached images), they will be automatically removed.
If that is the case, the option can be reset at Tools > Options > System Options > Advanced by selecting the relevant message.
There is no workaround in 2009.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Diego
regards, Diego
