A format with repeat regions drving the title block??
Hello everyone,
I am having a problem with trying to automate the creation of drawings by adding repeat regions to the title block. At the moment I have altered my current format by adding repeat regions to the cells in the title block. Now my title block is performing the same way as a BOM would, and appears to be working fine except for when I'm dealing with an instance from a family table. So let me explain what I'm doing and maybe someone can throw some advice at me. So I go to create a new drawing with my new drawing format and the first drawing I did worked fine. But then I went to do my second drawing and I noticed that it did not fill in my title block correctly. The model happened to be an instance of a family table and the info that was posted in the title block was that of the generic model and not the instance itself. I don't understand what I must do so that the repeat regions I added to my format will gather the correct information. The report symbol I am using in the repeat region is mdl.generic.User-Defined
RE: A format with repeat regions drving the title block??
This might give you better luck than using the repeat region feature, unless you need a list to be generated.
For a titleblock, just use a simple tables with the parameters you need to fill in the information.
Ben Loosli
