Converging Retaining Wall
Has anyone designed a new cantilever retaining wall that converged into an existing cantilever retaining wall? What are some issues/lessons learned with designing the new wall in close proximity or next to the existing wall?
RE: Converging Retaining Wall
Is the new wall above or below the existing wall?
If the new wall is above the existing wall, you do not want the toe of the new wall to impinge on the stem wall of the existing, and maybe not on the heel either.
If the new wall is below the existing wall, then you do not want to undermine the toe of the existing wall. The new wall may have to take the additional sliding force of the existing wall too.
There are also other considerations as mentioned above.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
