Proper Spec of Neoprene Bearing Pad
I am specifying a set of neoprene bearing pads for a small bridge span. I am not used to using this material and need to know what the proper way is to call out the pad on the drawings. I am assuming I need the outside dimensions, thickness, and hardness of the neoprene. Is there some kind of industry standard for how to call this out though?
RE: Proper Spec of Neoprene Bearing Pad
Attached is the standard detail for bearing pads from the Florida DOT...
ASTM D2000 M2BG714 B14 EA14
You have to look at the ASTM to figure out what all of the letters mean.
