Wax Cloud
Wax Cloud
We are currently having trouble with diesel blending regarding wax cloud. We have adjusted both light cycle oil, and kero. The LCO I assume should help, since it is very aromatic, but our LCO typically has a wax cloud number around 30-40, much higher than we would like. Does anyone have any insight into diesel blending and/or wax cloud issues?
RE: Wax Cloud
Orenda
RE: Wax Cloud
RE: Wax Cloud
Orenda
RE: Wax Cloud
So if you make belnds with Kero, SRGO, HAGO, LCO etc they will all follow these correlations to a high degree. There are deviations hence you might have to correct the blend to some extent but if the components are analysed correctly (as well are representative) you should come out quite close
The additive suppliers can help you with chemicals that affect one or several of the cold flow properties to a certain extent. The response is however very dependent on the compostion and the components used. That is the reason why freqeunt additive testing is needed.
Will dig in the litterature and see if I can find an algoritm for your problem
RH
