Set "Files of type" to CATPart
When opening a document in Catia V5 the field "Files of type" is set to "All Files(*.*)" by default.
Can this be changed so the default is always set to CATPart?
RE: Set "Files of type" to CATPart
First thing which came in my head is to create a bat file.
Copy next "code" in a txt file and change the extention from txt to bat (eventually put it on desktop)
START "" CNEXT.exe -workbench "Part Design"
In fact, you can start CATIA directly with run command from Windows start menu. You have bellow few examples
CNEXT.exe -workbench "Part Design" - Initiate CATIA in Part Design Workbench
CNEXT.exe -workbench "Generative Shape Design" - Initiate CATIA in Generative Shape Design Workbench
CNEXT.exe -object c:\_Migration\Test.CATPart -Initiate CATIA with a CATPart found in folder c:\_Migration\Test.CATPart
Of course, Test.CATPart can be a template part but you have to take care to save it with a new UUID (see FAQ section).
Fernando
