postbuilder machine axis
Hi guys,
I want to know, how can I customize machines axis on postbuilder. For 3 axis horizontal and vertical milling center and 4 axis milling centers too.
How can I change machine axis, from horizontal +Z to vertical +Z and vertical+z to horizontal +Z
See you soon, thanks.
RE: postbuilder machine axis
You can however, create a new post, with new kinematics, using another post as a controller.
What this will do is bring in all customization that you have done to a new machine type.
Search the help file for "Changing Postprocessor Kinematics"
Also, see attached picture
Hope this helps,
JAY
I see, I tried to change the done post...
I was wrong.
See you.
