Weight of pipe fittings
I don't know if this is the correct forum, if not please advise for the correct forum.
I'm looking for information which gives me the weight of different pipe fittings (Elbows, t-pieces, reducers etc) according ASME. I ave documentation of van Leeuwen buizen from the Netherlands but I want to make a counter check to see if everything is correct. Can you suplly me with a URL of a supplier who has this information in a catalog on his website
Many thanks
RE: Weight of pipe fittings
Many thanks for your quick reaction. the only trouble is that I can't download the file. Maybe it has to do with the spaces in the name?
The server appears to be broken.  I'll report it.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
I suggest that you go here:
http://www.pipingdesigners.com/Tools.htm
Scroll down to "Calculators"
item 3 is an Excel workbook for Metric piping weights
item 4 is an Excel workbook for Imperial piping weights
Read page 1 and follow the instructions.
