Replaceing a 250v bulb with a 120v bulb
This is my first post here so please go easy on any mistakes I might make. :) My question is simple.. I have been trying to come up with a way to wire a 120v bulb to a 250v circuit. I'm very new to EE and I was doing some research on the issue and came up with this...
I bought an LED I found at my local radio shack and the only thing I could find that would fit and had the highest voltage rating was a 120v 1.5mA. I'm replacing a bulb and wanted an LED instead.
R=(V1-V2)/I
R=(250V-120V)/1.5mA
R=130V/0.0015A
R=86,666.6667ohms (wow big resistor!)
Now... I'm more then likely not going about this the right way but from what I have read into this was right... So is is possible to wire my 120v 1.5mA LED to a 250v 1/3w circuit?
**Notes
The 250v 1/3w is all I have to go by off the bulb harness I'm replacing...
R=(V1-V2)/I
R=(250V-120V)/1.5mA
R=130V/0.0015A
**Notes
RE: Replaceing a 250v bulb with a 120v bulb
1) I can't find anyone around here that sales a 250v 1/3w bulb or led that is small enough for this application.
2) I love doing things the hard way because I learn a great deal more with my hands on with the project!
In saying that, I was so stupid when talking about the resistor size... I was looking a a 270ohm resistor at the time and didn't even think about the k in 87k hehe.
Ok so here is what I have to work with unless I go back out to the store... :)
Could I use the 120VAC 1.5mA LED with a 100k-Ohm 1/2 watt resistor?
Arvo Bowen III
http://xeonics.net
But my plans were to ADD a 100k-Ohm 1/2 watt resistor to the circuit... just to check, do I need to add a cap to it? I thought caps were just used to store power or regulate it...
I definitely want to NOT have a hot led if I can avoid it.
Arvo Bowen III
http://xeonics.net
My suggestion is to just buy one too.
http://www.ledtronics.com/Products/Default.aspx
Keith Cress
TTFN
Don't even think of what?.....There have been a half dozen suggestions.
Wisdom comes from knowledge
Knowledge comes from experience
Experience comes from bad decisions
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
I saw the diode and resistor only used on HV AC more than 20 years ago and thought of it as one of those cost saving Chinese engineer tricks. I tested it then and just about a year ago with line voltage. I didn't get any measurable reverse voltage leakage at 150V.
I knew there just had to be a limit so I ran the test again this time using my Sencore LC101. I have come to love this instrument for the leakage tests it can do up to 1000V. The LED was tested for leakage at 50V, 100V, 200V. Not a uA was seen. When switched to 300V it failed and never recovered.
If a resistor is added, a diode will also be required in series. Stupid engineer tricks only get you so far!
You had to have realized the breakdown/gap voltage of the cap would be reached eventually... the concept is still sound, you just need a different style of cap (i.e., more expensive) for the higher voltage.
Dan - Owner
http://www.Hi-TecDesigns.com
If just a resistor is added in series the LED will breakdown from higher reverse voltage and be destroyed. It is obvious that some manufacturers understand that a LED can withstand normal 120V line voltage. Adding a diode in series with the 68K resistor will prevent reverse voltage breakdown when voltage goes from 120 to 250V.
Arvo Bowen III
http://xeonics.net
20mA and produces about a 2V voltage drop
however since its a type of diode which doesn't coope well with reversed voltage of 250V, a good configuration would be:
a LED with a resistor in series of 248V/20mA =12kOhm
and 20mA x 248V= 0.5watt
parallel over the LED you connect a diode (anode LED to kathode diode and vice versa), this way the reversed voltage will not exceed 0.7V
0.7V x 250/12Kohm gives the power rating of the diode
Dan - Owner
