drilling problem
drilling problem
I need to drill a hole in 12mm flat bar. The hole is to take 20mm round bar.The angle of the hole needs to be 40 degrees. I have a drill press and can set the base to 40 degrees. How do i get a hole (pilot) to start without bending drill from center punched mark?
I need to do 3 such hole along the length of bar.
thanks
thanks
RE: drilling problem
ISZ
