Privoxy block
Privoxy block
Privoxy block
When I try to access certain things on the internet I get a screen that says blocked by Privoxy.  In some of these instances, it allows me to override the block but for example;  Privoxy will not allow me give a star to postors in eng-tips.
Does anybody know how to fix this or at least a way  to override it in specific cases?
mad or mad
RE: Privoxy block
I'm guessing Privoxy is something installed on your own computer that prevents you from running Javascript.
Mike Halloran
Pembroke Pines, FL, USA
RE: Privoxy block
Thanks Mike,
I noticed that IRStuff suggested to the postor on thread233-261763: Password manager not working in Firefox to repost at Tek-Tips and his subject seems much closer to the intent of this forum than my question.
Would I be guilty of double posting if I post on Tek-Tips?
Actually I should post this question at tech-forums.net.
I received help there on an ms-word problem but I found that source after posting the above question here.
RE: Privoxy block
You would not be guilty of double- posting by posting on Tek-Tips; it's run by the same outfit, but is separate.
(We want to keep it that way, so please don't mention Eng-Tips.)
Mike Halloran
RE: Privoxy block
Tek-Tips is solely a computer issues forum, and as such, more likely to have the audience and expertise with your problems.
Ostensibly, this forum is supposedly intended to deal with questions about the design and engineering of computers and computer systems, although I have to admit that I've almost never seen the questions I think this forum is supposed to service.
TTFN
RE: Privoxy block
Thanks for the clarification.
RE: Privoxy block
Sounds like it is a proxy blocking certain pages from your computer.
Are you accessing from the workplace? If so check with the IT department for permission to bypass.
Are you accessing from home? Then you may be dealing with a connectivity or browser issue. Unless someone else who uses that computer installed a software to block certian sites.
Peak to Peak Power
http://www.peaktopeakpower.com
http://www.peaktopeakled.com
