Insert same part in assembly, multiple times
I want to make an assembly where I need to add several of the same item.  Is there a way to add multiple parts?  Or do I have to add the same part one at a time?
drawn to design, designed to draw
RE: Insert same part in assembly, multiple times
Depends on what you are trying to add.
Maybe look into Component Patterns and Derived Component Patterns in Help.  That's about the only way I know beyond just clicking and dragging components already in the Feature Tree into the Assy.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
You can do a CTRL-drag from the FM or you can drag and click as many times as you want from your design library.
Dan
www.eltronresearch.com
Dan's Blog
You can also just CTRL-drag a component directly in the graphics window to copy it to a new location.  This is a really fast way to place a lot of the same part into the assembly.
ctrl+drag works well for components, but not sub-assemblies. For sub-assemblies, you have to grab it out of the FM or you'll end up just dragging a component of the sub-assembly.
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
Pattern it (Rectangular, circular or feature based). Retain the pattern if suitable or dissolve it.
For Help Click Here
~ BT
Watch patterning a components/features. Depending on many components/features you pattern, you could cause some performance degradation.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
